What is the “helicorder scale value” in the rs.local set page of RS? And what are the conduction to set a high or low value?
- a higher number will result in the trace looking like it has higher amplitudes
- the opposite for lower numbers
try setting different values, examining the results, and deciding for yourself what works best for your use case.
