Hello Diego,
You’re welcome, I’m here for this.
Regardinng the errors present in the odf_SL_plugin.err file, some are related to the fact that the Shake is not connected to any network (since it is out in the field) and are explained by these lines:
|2021 138 17:11:29>>|sendDClientDP(): Error sending data ... |
|2021 138 17:12:09>>|create_socket(): Error in getaddrinfo: Name or service not known|
|2021 138 17:12:09>>|Likely cause is no DNS server found.|
Thus, they are not related to anything GPS, they are simply stating that the OS is not finding any network to transmit data to. This is a consequence of setting Data-Sharing Mode : ON on rs.local/ Settings -> Data page. If you uncheck the box, these should disappear from that log file.
Regarding these other errors:
2020 219 00:41:48>> JSON Packet error: ':' expected near 'MA'
2020 219 00:41:48>> Cannot process record, throwing it away.
2020 219 00:41:48>> {'MA': 'RS3D-5-4.1','DF': '1.0','CN': 'EH2','T{'MA': 'RS3D-5-4.1','DF': '1.0','CN': 'EH2','TS': 0,'TSM': 0,'TQ': 45,'SI': 5000,'DS': ['FFFFBF28','FFFFBFD5','FFFFBF01','FFFFBE43','FFFFBF1E','FFFFC01B','FFFFBF4E','FFFFBE0E','FFFFBED9','FFFFC04C','FFFFBF8B','FFFFBDF4','FFFFBE5B','FFFFBFF8','FFFFBFFD','FFFFBEAD','FFFFBE67','FFFFBF33','FFFFBF4A','FFFFBEBE','FFFFBF41','FFFFBFF6','FFFFBEFD','FFFFBDE4','FFFFBEEA','FFFFC03C','FFFFBF6A','FFFFBE07','FFFFBEA3','FFFFC02B','FFFFBFAA','FFFFBE0E','FFFFBE2E','FFFFBFA4','FFFFBFF6','FFFFBF3E','FFFFBEFD','FFFFBF08','FFFF{'MA': 'RS3D-5-4.1','DF': '1.0','CN': 'EH2','TS': 0,'TSM': 0,'TQ': 45,'SI': 5000,'DS': ['FFFFBFA6','FFFFBE7B','FFFFBEC1','FFFFBFDE','FFFFBF90','FFFFBE61','FFFFBEEC','FFFFC053','FFFFBFC6','FFFFBE48','FFFFBE81','FFFFBFFB','FFFFBFF2','FFFFBEB0','FFFFBEB8','FFFFBFD2','FFFFBFB0','FFFFBE91','FFFFBEC4','FFFFBFD1','FFFFBF9C','FFFFBEC9','FFFFBF2A','FFFFBFF8','FFFFBF82','FFFFBE63','FFFFBEB7','FFFFBFF0','FFFFBFBD','FFFFBE93','FFFFBEFB','FFFFC016','FFFFBF96','FFFFBE5E','FFFFBEAB','FFFFC01B','FFFFC013','FFFFBEB8','FFFF{'MA': 'RS3D-5-4.1','DF': '1.0','CN': 'EH1','TS': 0,'TSM': 0,'TQ': 45,'SI': 5000,'DS': ['4252','4252','408B','4064','41D1','420C','40D8','407B','41EE','4280','40EA','4050','418A','41DE','40E3','4101','422A','41FC','404F','4046','4213','4256','40C3','4084','41DA','421C','40EB','4078','41AA','4205','40CF','40B8','4217','41FE','407B','4095','420C','421F','40BE','409A','420E','4233','40A8','4041','41BA','4204','40D9','40DB','422C','4227']}
these represent corrupted data that was impossible to interpret properly and has been thus discarded. The reasons could be multiple, but the general recommendation is to check every connection of the Shake to make sure that nothing is loose. Also, we recommend, after this check, to turn on the Shake again and to let it run for some time in the same conditions it was in the field, to see if such events happen again. If they do, the new logs could give us more insight on what is actually happening.
