I believe I have my shake working but can’t tell if the Boom is actually functioning. My station does not light up on the Boom network map whereas others do. Can’t find any info in the manuals and quick starts. Help?
Can I presume that EHZ refers to the shake signal and HDF the boom signal?
Hi Tom, yes HDF is the infrasound data. If you install SWARM on your PC, you can see if the data is being recorded by the community server (the return data has a 30-40 minute delay).
Make sure you have the “Forward data” check box turned on in the setup screen
