Frequency filter ringing in EQ Locator web app
Applying the ‘Regional’ ‘Global’ ‘Local’ etc. filters in EQ Locator invariably results in spurious large amplitude artifacts appearing at the left edge - so large that the scaling is thrown out making the signal of interest almost imperceptible. Presumably this arises from the Fourier frequency filter not properly allowing for the sharp edge effect (ringing). Can you eliminate this?
Hello MarkDman,
Thank you for the notification! I will pass it to our development team so that they will be able to check and correct the issue as soon as they have time.
Thanks again for your interest in our applications!
