Client('http://data.raspberryshake.org') which is not down but is definitely not returning any data.
I tried using my own ID " RA9CD" and also the one you provided as a working example in a previous ticket “R5B5C” but nothing is working. So its seems like a server issue. Here is my evidence code in case you want to check it.
I’ve tested Client('http://data.raspberryshake.org'), and it seems to work for the most recent data. I’ve asked our server team to check why it would not retrieve your data.
Thank you also for sharing the code. As far as I can see, there is nothing wrong with it, and it’s a very clean one!
Apologies for this inconvenience. You can rest assured that we’ll see it solved.
I tried again multiple times during yesterday and tomorrow and I get no response. No problem, I am attaching the the full code here in case you want to easily test yourselves.
The team told me that they are aware of this intermittent service (while we know that the data is available to be downloaded via FDSNWS) and are working to fix it.
Just as an update, today, 10 minutes ago. I was trying to retrieve data again and 9/10 requests gave me data, which is great. I imagine you are doing some infrastructure updates, so just to let you know, it seems to be working.
Thanks a lot, I was able to get the data I needed.
Thank you for confirming this. Yes, our team completed the final tests yesterday and I’m happy to report that the services are working fine with the new infrastructure in place.
