Im trying to install rsudp on a raspberry pi 4, and i keep getting an error while it tries to upgrade pip, ive tried to do it manually but im not very advanced on this kind of issues. The error is the following:
(base) pi@raspberrypi:~/rsudp $ bash unix-install-rsudp.sh
Looking for existing installation...
Found anaconda at /home/pi/miniconda3
No rsudp environment found.
Starting install script.
Raspberry Shake UDP client installer v0.3
Ian Nesbitt, Raspberry Shake S.A., 2022
Please follow instructions in prompts.
Press Enter to continue...
This script will need to use or create a directory to store miniSEED data and screenshots.
Common choices might be /home/pi/rsudp or /home/pi/opt/rsudp
Where would you like the rsudp output directory to be located? You can use an existing one if you would like.
Press Enter when done (if no input is given, the script will use /home/pi/rsudp):
No directory was provided, using /home/pi/rsudp
Using existing directory /home/pi/rsudp
Looking for conda installation...
Anaconda installation found at /home/pi/miniconda3
conda executable: /home/pi/miniconda3/bin/conda
Source line already exists in /home/pi/.bashrc
Sourcing...
Activating conda...
Found conda-forge channel in /home/pi/.condarc
Creating and installing rsudp conda environment...
Collecting package metadata (current_repodata.json): done
Solving environment: failed with repodata from current_repodata.json, will retry with next repodata source.
Collecting package metadata (repodata.json): done
Solving environment: done
==> WARNING: A newer version of conda exists. <==
current version: 4.9.2
latest version: 23.5.0
Please update conda by running
$ conda update -n base -c defaults conda
## Package Plan ##
environment location: /home/pi/miniconda3/envs/rsudp
added / updated specs:
- cryptography
- future
- lxml
- numpy=1.16.4
- python=3
- scipy
- sqlalchemy
The following NEW packages will be INSTALLED:
_libgcc_mutex pkgs/main/linux-aarch64::_libgcc_mutex-0.1-main
_openmp_mutex conda-forge/linux-aarch64::_openmp_mutex-4.5-2_kmp_llvm
blas conda-forge/linux-aarch64::blas-2.114-openblas
blas-devel conda-forge/linux-aarch64::blas-devel-3.9.0-14_linuxaarch64_openblas
ca-certificates pkgs/main/linux-aarch64::ca-certificates-2023.05.30-hd43f75c_0
certifi pkgs/main/linux-aarch64::certifi-2022.12.7-py37hd43f75c_0
cffi pkgs/main/linux-aarch64::cffi-1.15.1-py37h998d150_3
cryptography pkgs/main/linux-aarch64::cryptography-39.0.1-py37h3d58568_0
fftw pkgs/main/linux-aarch64::fftw-3.3.9-hfd63f10_1
flit-core pkgs/main/noarch::flit-core-3.6.0-pyhd3eb1b0_0
future pkgs/main/linux-aarch64::future-0.18.3-py37hd43f75c_0
greenlet pkgs/main/linux-aarch64::greenlet-2.0.1-py37h419075a_0
icu pkgs/main/linux-aarch64::icu-68.1-h22f4aa5_0
importlib-metadata pkgs/main/linux-aarch64::importlib-metadata-4.11.3-py37hd43f75c_0
ld_impl_linux-aar~ pkgs/main/linux-aarch64::ld_impl_linux-aarch64-2.38-h8131f2d_1
libblas conda-forge/linux-aarch64::libblas-3.9.0-14_linuxaarch64_openblas
libcblas conda-forge/linux-aarch64::libcblas-3.9.0-14_linuxaarch64_openblas
libffi pkgs/main/linux-aarch64::libffi-3.4.4-h419075a_0
libgcc-ng pkgs/main/linux-aarch64::libgcc-ng-11.2.0-h1234567_1
libgfortran-ng pkgs/main/linux-aarch64::libgfortran-ng-11.2.0-h6e398d7_1
libgfortran5 pkgs/main/linux-aarch64::libgfortran5-11.2.0-h1234567_1
liblapack conda-forge/linux-aarch64::liblapack-3.9.0-14_linuxaarch64_openblas
liblapacke conda-forge/linux-aarch64::liblapacke-3.9.0-14_linuxaarch64_openblas
libopenblas conda-forge/linux-aarch64::libopenblas-0.3.20-pthreads_h6cb6f83_0
libstdcxx-ng pkgs/main/linux-aarch64::libstdcxx-ng-11.2.0-h1234567_1
libxml2 pkgs/main/linux-aarch64::libxml2-2.9.14-he30c317_0
libxslt pkgs/main/linux-aarch64::libxslt-1.1.35-hd0e857b_0
llvm-openmp pkgs/main/linux-aarch64::llvm-openmp-14.0.6-h308e764_0
lxml pkgs/main/linux-aarch64::lxml-4.9.1-py37h33836a5_0
ncurses pkgs/main/linux-aarch64::ncurses-6.4-h419075a_0
numpy conda-forge/linux-aarch64::numpy-1.16.4-py37h91f3968_0
openblas conda-forge/linux-aarch64::openblas-0.3.20-pthreads_h2d9dd7e_0
openssl pkgs/main/linux-aarch64::openssl-1.1.1u-h2f4d8fa_0
pip pkgs/main/linux-aarch64::pip-22.3.1-py37hd43f75c_0
pycparser pkgs/main/noarch::pycparser-2.21-pyhd3eb1b0_0
python pkgs/main/linux-aarch64::python-3.7.16-h89984f6_0
readline pkgs/main/linux-aarch64::readline-8.2-h998d150_0
scipy pkgs/main/linux-aarch64::scipy-1.7.3-py37h8708280_2
setuptools pkgs/main/linux-aarch64::setuptools-65.6.3-py37hd43f75c_0
sqlalchemy pkgs/main/linux-aarch64::sqlalchemy-1.4.39-py37h998d150_0
sqlite pkgs/main/linux-aarch64::sqlite-3.41.2-h998d150_0
tk pkgs/main/linux-aarch64::tk-8.6.12-h241ca14_0
typing_extensions pkgs/main/linux-aarch64::typing_extensions-4.4.0-py37hd43f75c_0
wheel pkgs/main/linux-aarch64::wheel-0.38.4-py37hd43f75c_0
xz pkgs/main/linux-aarch64::xz-5.4.2-h998d150_0
zipp pkgs/main/linux-aarch64::zipp-3.11.0-py37hd43f75c_0
zlib pkgs/main/linux-aarch64::zlib-1.2.13-h998d150_0
Preparing transaction: done
Verifying transaction: done
Executing transaction: done
# To activate this environment, use
# $ conda activate rsudp
# To deactivate an active environment, use
# $ conda deactivate
Activating rsudp environment...
Success: rsudp environment activated.
Upgrading pip...
/home/pi/rsudp/bin/unix-install.sh: line 247: 10484 Illegal instruction pip install -U pip
Something went wrong.
Check the error output and try again.
