Hi there,
Does the sound tool not work currently? I have tried downloading sounds for events but it is always stuck at “generating 0/0”.
Hi there,
Hello VS1,
Thank you for the report. Could you please tell me all the info that you put in the Sound App, so that I can try to recreate the issue?
I have attached what I enter
Station : R5B60
Trace date : 13 May
Time : 7:43pm
Reduced to 4 times slower for local quake.
Thank you VS1, I was able to re-create your issue and have opened a ticket for our software team to take a look at it.
I will update you as soon as I have news.
Thank you for your patience.
Hello VS1,
The error has been found and fixed. Everything should work fine now.
I advise you to open the app and then hard refresh it (with Crtl+F5
or MAC equivalent) before starting to use it, to ensure that any stored cookie will be reset. I have tested the same info you have provided, and, albeit a bit slowly, the trace was fully generated.
