Is the EQ Sound app down?
Hi
Thanks for the report, it seems a server restart did indeed crash the sound app 3 days ago.
We are looking to it and we will let you know here in the next couple of days when it is available again.
Sorry for the inconvenience.
Sound is back up and running, let us know if you experience anymore issues.
Hi, Is the EQ Sound app down again?
Hello Edgardo, and welcome to our community!
Yes, it appears that the Sound App is down, and I have asked our team to check what issue is causing this error.
I will update again when everything will be online again. Thank you for your notification and patience.
EDIT: Update, everything has been solved and the EQSound service is back online. If you still see an error page, please refresh your browser with Ctrl+F5 or Mac equivalent. Thank you.
Thank you very much for the welcome and for the solution, now everything is working fine.
The EQ Locator isn’t working properly. After entering a station name, the “spinner” on the left just spins …
You are correct Philip, we have located the issue and are working to solve it.
Thank you as usual for your notification.
Just a fast note that we have managed to fix the issue causing the problem in EQLocator, and it is now working again.
