Has anyone had any experience with a “ImportError: DLL load failed while importing _arpack: The specified procedure could not be found.”?
The background is originally I installed Python 3.10 on my windows desktop computer and was using that quite happily although I could not install Cartopy.
I found that by installing Anaconda I could get python 3.9 installed with Cartopy and did that. After doing so, I found 3.10 was still reliable by 3.9 was not. Presumably the two versions weren’t happy together.
I installed anaconda and python 3.9 on my new laptop and it works fine, so I decided to unistall 3.10 on my desktop and concentrate on 3.9 with both Obspy and cartopy. Problems got worse, so I checked all PATH environment variable and got rid of references to the python 3.10 locations.
Eventually I uninstalled anaconda and reinstalled and set up Cartopy and Obspy again, but this error persists. It happens on all my reports.
The line in my program/module seems to be the “from obspy.signal import filter”. All the calls after that appear to be in modules outside my program.
Here’s a copy of the console output:
I appreciate any help anyone can suggest. I haven’t yet sat down with my laptop to check it still works as it did last week, and check off versions of the various modules. I suspect it is something else as Anaconda is supposed to manage compatibility between the modules.
Al.
