I just set up my raspberry shake model a couple days ago. It is a seismograph, and one of the older versions so its Component Code is SHZ.
I noticed the readings of my shake, and all the other SHZ ones were getting a much wider range of values with both negative and positive values in meters/second. But when I looked at the EHZ raspberry shakes I saw they had a much smaller range and they were completely positive values.
I was wondering how that was possible since the ground vibrations should not change based on what model shake you use.
Thanks in advance,
Arushi
