Dear,
How do I delete the RS station data before the period I set in Wave Form Saving? I have tried by FileZilla, but to no success.
Best Regards
Dear,
Best Regards
Hello Manuelle, welcome to the community!
the files will be automatically deleted after the time you set up in Config → Data → Waveform Data Saving has passed. It is set as 7 days by default, if you haven’t changed it.
https://manual.raspberryshake.org/download.html#general-comments
Do you require to erase the files on the Shake for some particular reason?
I am using RS to monitor civil works in a location without internet. My need is after downloading the data to delete them immediately so I can return with the stations to the field, I was wondering how I can do this operation?
Best Regards
Ah perfect then.
The data files are located in this folder, once you SSH into the Shake (guide here: How to access your Raspberry Shake’s computer via ssh — Instructions on Setting Up Your Raspberry Shake):
/opt/data/archive
You can use the rm
command to remove all the content inside this folder, so your Shake will be ready to go back to the field!
sudo rm -r /opt/data/archive
If you are using WIndows, you can use PuTTY
to do this.
