DataView Suggestion - selection cursor
In the helicorder view, the it would be really useful if there were an option to “fix” the parameters of the selection cursor (start/end times) so that when looking at an event on multiple different devices the expanded display was directly comparable.
Currently, taking screen shots of the expanded display for several devices is a pain to correlate, because at best, the start/finish times don’t exactly correlate, so working out timing isn’t a simple matter of just looking at the captured traces.
Example of a recent local event, only captured on three devices:
Yes, if I had been a bit more careful, I would probably have got the time range the same, or at least close, but getting the start time to match is close to impossible. If I could fix the selection cursor start/finish times then swap between devices, life would be much easier.
