Does anyone else get this?
Some times the scales in dataview are obviously not right. This example is from the multi-stream display.
Al.
Al.
Hello Al,
Thank you for noticing this, there is definitely something wrong. I will open a ticket so that we can see this solved as soon as possible.
Thanks!
I have seen it from time to time. It is simply a problem with calculating the zero value - remember that the raw output of the device is “counts”, and on mine, the average value of the counts (zero) is ~16600.
I don’t know if all devices of a specific model have the same “zero” count, and they use a lookup table, or if they try to grab a sample of data to use to calculate a running average or what, but sometimes, it is incorrect.
