I started this on another thread but this is enough of a change in topic that I decided to start new thread to make it easier to find.
This relates to attaching a 256 GB SSD drive to the rs for greater data capacity. Current card is 32 GB. I followed the instructions on the link given by Stormchaser and all seemed to be well, but the rs.local page still shows that I only have 25 Gb available instead of 200+. Below is the output for the command sudo dmesg -T. I have tried to replace the drive with another unformated SSD so see if it is a drive issue, but then the rs does not even boot. Thx guys… -Mario (AM.SDE97)
If you haven’t had any errors during the mounting procedure, the added SSD has been correctly set up.
Now that some time has passed, if you execute df -h | grep sda1 (sda1 should be the reference of your external drive. Update it if it’s different) a couple of times, waiting between them, you should see different values in the command output. That indicates that all your data is being saved on the SSD.
As of now, rs.local/ does not reflect the added storage and the command above is the easiest way to check. Otherwise, you can navigate the external drive folder structure (via command line or software such as FileZilla) to achieve the same result.
PS: have been picking up significant number of local quakes up to 4.2 in the southern Idaho area. Also picking up the 5+ ones up in Alaska clearly… all way from Idaho!!! NICE!
PSS: also your youtube tutorials and lectures have been instrumental in ability to interpret things better and more quickly. Thanks for doing those. VERY valuable.
