Hello. we turned on two stations in Georgia. When testing in the office, we manually entered the coordinates and altitude, because we didn’t have GPS yet. I used it directly while working in the field. I read that in order for the GPS to start working, I had to turn off the sensor, connect the cable, and then turn on the Internet connection. I didn’t know this information before, but I remember exactly that in the field, I first connected all the cables and then turned on the sensor. When I checked before leaving, the location still showed the manually entered location, as well as the altitude… I thought it might take time, but I’ve been out for 1 week and it’s the same. In short, I’m wondering how I can find out if the GPS is connected or not, or if it is, how can I configure the sensor to take the GPS information and not the manually entered one.
Unfortunately, we don’t have IP access from the office, but if you explain how it can be solved, I might go to the field.
The station is connected to the Internet via a router, but we didn’t set a static IP and I think I made a mistake. I don’t have access to log files, for example.
