Hello Danielle,
I’m sorry to hear that the new ISP is causing this, let’s see if we can tackle them from our side.
From the postboot.log
file, these lines explain the issue as a DNS problem:
2020 261 21:19:19: Unable to resolve hostname 'raspberryshake.net', most likely no DNS server available
2020 261 21:19:19: No internet connection found
2020 261 21:19:29: Unable to resolve hostname 'raspberryshake.net', most likely no DNS server available
The first thing you can try (and good work with the 55555:55556
ports) is to check that the following is open too (if not, please open it):
port 123
for TCP and UDP traffic in both directions
This port is used by the NTP time synchro service, which is essential for data upload to our servers: if the NTP service
doesn’t work, or stops working, then everything else along the data transmission line fails, and no data is uploaded to our servers, as I am sure you have reasoned.
If you have opened it, restart the Shake and wait to see if Server Connection
in rs.local
switches to Connected
If this does not happen, then you can also try to change the DNS on the Shake, as explained in this page on our manual, https://manual.raspberryshake.org/firewallIssues.html#how-to-manually-change-dns, to see if this solves the issue. I’ll add some more info below.
There are two possible ways: setting a manual IP and DNS in the http://rs.local web config, or adding a line to /etc/dhcpcd.conf
in the Shake filesystem.
The first doesn’t require logging into the Shake. Navigate to rs.local
, make note of the Shake’s IP address, then click on the Settings
gear icon (high on the left) to access the configuration menu.
Fill out the DNS server field with a more reliable DNS service. OpenDNS
, which is 208.67.222.222
, is a good choice. You can also use Cloudflare
DNS service by entering 1.1.1.1
or Google
by entering 8.8.8.8
SSH into the Shake (guide here: https://manual.raspberryshake.org/ssh.html)
sudo service dhcpcd restart
nano /etc/resolv.conf
# Generated by resolvconf
nameserver 1.1.1.1
nameserver 1.0.0.1
