Hello, I am unable to get any conda besides miniforge to work. Is it possible to use miniforge instead or do you have any other ideas? I am on Raspberry Pi OS 32bit on a Raspberry Pi 4B.
Here is the full terminal:
matthew@raspberrypi:~/bin/rsudp $ bash unix-install-rsudp.sh
Looking for existing installation...
Starting install script.
Raspberry Shake UDP client installer v0.3
Ian Nesbitt, Raspberry Shake S.A., 2022
Please follow instructions in prompts.
Press Enter to continue...
This script will need to use or create a directory to store miniSEED data and screenshots.
Common choices might be /home/matthew/rsudp or /home/matthew/opt/rsudp
Where would you like the rsudp output directory to be located? You can use an existing one if you would like.
Press Enter when done (if no input is given, the script will use /home/matthew/rsudp):
No directory was provided, using /home/matthew/rsudp
Successfully created output folder /home/matthew/rsudp
Looking for conda installation...
Cannot find conda installation; will try installing miniconda3.
Found Linux environment on aarch64.
Install location: /home/matthew/miniconda3
Ready to download miniconda3
The download could be as large as 200 MB.
Press any key to continue or Ctrl+C to exit...
--2023-07-20 01:55:47-- https://repo.anaconda.com/miniconda/Miniconda3-4.7.12-Linux-x86_64.sh
Resolving repo.anaconda.com (repo.anaconda.com)... 2606:4700::6810:8303, 2606:4700::6810:8203, 104.16.130.3, ...
Connecting to repo.anaconda.com (repo.anaconda.com)|2606:4700::6810:8303|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 70489432 (67M) [application/x-sh]
Saving to: ‘/tmp/conda-install.sh’
/tmp/conda-install.sh 100%[========================================>] 67.22M 4.39MB/s in 13s
2023-07-20 01:56:00 (5.10 MB/s) - ‘/tmp/conda-install.sh’ saved [70489432/70489432]
Installing miniconda3...
PREFIX=/home/matthew/miniconda3
Unpacking payload ...
./conda-install.sh: 351: /home/matthew/miniconda3/conda.exe: Exec format error
./conda-install.sh: 353: /home/matthew/miniconda3/conda.exe: Exec format error
Cleaning up temporary files...
Updating base conda environment...
/home/matthew/bin/rsudp/bin/unix-install.sh: line 157: /home/matthew/miniconda3/bin/conda: No such file or directory
The script will now append a sourcing line to your ~/.bashrc file in order to
make activating conda easier in the future (just type "conda activate" into a terminal).
This line is: . /home/matthew/miniconda3/etc/profile.d/conda.sh
Press Enter to continue, or type no and press Enter to prevent this...
Appending sourcing line to bashrc...
Sourcing...
/home/matthew/bin/rsudp/bin/unix-install.sh: line 194: /home/matthew/miniconda3/etc/profile.d/conda.sh: No such file or directory
Activating conda...
/home/matthew/bin/rsudp/bin/unix-install.sh: line 196: conda: command not found
ERROR: Anaconda install failed. Check the error output and try again.
