Hello waw0102,
Thank you for posting the logs of both Shakes. From them, it appears that there are mixed errors and network communication issues that could be causing your lack of connection. Could I please ask you to:
- shut down both Shakes and their modem/router
- disconnect the Shakes’ power and LAN cables
- start the modem/router again and wait for it to regain internet connection
- reconnect the Shakes’ power and LAN cables (try the LAN cable to a different port on the modem/router)
- turn the Shakes on again
- wait for two/three hours, download the new logs and send them here?
I would like to have freshly started Shake logs to compare with the logs you’ve just sent me.
Regarding RSUDP (answering here so that we can keep everything neat in a single topic), this is likely related to the server issues we have been experiencing (updates here: Live Data Issues).
To fix this, you could temporarily modify a line in the raspberryshake.py file, editing https://fdsnws.raspberryshakedata.com/fdsnws/station/1/query? to https://stationview.raspberryshake.org/fdsnws/station/1/query?
This will restore RSUDP capabilities of acquiring the station response file.
Thank you!
