I cannot access my RS4D, which is currently in online mode, due to an internet outage in our area. Is there a way to access it while the internet connection is unavailable?
I also tried accessing it directly and restarted the RS4D multiple times, but there has been no progress.
This issue also happened previously, but it was resolved once the internet connection became available again.
Please note that my RS4D is already updated to the latest version.
The reason I am asking is that the previous version of the RS4D worked properly with or without an internet connection. I would like to know if there is a setting, procedure, or PowerShell command that can enable standalone mode so that the current version can be accessed locally even when there is no internet connection, while allowing me to switch back to online mode once the internet connection is restored.
Hello waw0102,
Yes, it is possible to connect directly to the Shake even without an internet connection.
To do so, configure your PC/laptop IP address to be in the same range as the Shake Discovery IP. For more details, see this page in our manual.
Once you have updated your PC/laptop IP, you can run an Ethernet cable from your computer to the Raspberry Shake, and you should now be able to ping the Shake itself.
