I’ve just noticed that I cannot connect to MyShake through WWS with Swarm.
The error I get is:
2021-05-18 02:47:15 ERROR - Error connecting to 192.168.4.74 192.168.4.74:16032 in WWSClient. (java.nio.channels.UnresolvedAddressException)
I have been able to connect in the past.
I am running on home network and my router has a recently upgraded system.
I rebooted my Shake but still cannot connect via Swarm.
I think I have fixed the 2 different IP addresses by plugging the ethernet cable into the unit. When I log into rs.local I see that it shows the IP address as Ethernet Local IPv4 : 192.168.4.42. I’ve also disabled Wifi on the Shake. Now the router only shows 1 IP address assigned to the unit.
When I try to connect using SWARM using 192.168.4.42 I am still unable to connect…
It’s no problem at all, you’re welcome! Thank you for your further explanations, could you post here a screenshot of the WWS configuration screen on SWARM? So that we will not be doing a to and from asking for info and I will have everything I need.
Just as you suggested. With one entry removed it works as it should. The second IP address entry must be a leftover from my mistake of leaving Wifi checked on in the rs.local configuration even though I was connected by cable. This caused the router to assign 2 ip addresses.
