Can I hook up my Raspberry Shake to a chromebox? I tried but can not get it to connect.
What do you mean by “hook up”?
If you mean can you access the r-shake web server, yes, it’s a normal HTML webserver, and the Chromebook runs a Chrome browser - basically the same one I use to access my r-shake.
It is not clear from what I can see on Google if the Chromebook supports zeroconf/Bonjour which is used to broadcast the name and IP address to add the rs.local address to a client.
If that is not supported by the Chromebook, you will have to use the IP address of the r-shake to access it.
Thank you I will try again and see what happpens
