I don’t seem to manage to access rs.local:5000 even if we are on the same on network.
Edit: The LAN port on my raspberry pi 3 b+ is orange and blinking.
Have you tried finding the IP address with Fing and using that instead?
No I wasn’t able to. Is it possible to have my rshake connect to WiFi on first boot?
Are you on a school or university network? If so, probably not.
If you are at home and this is happening, I recommend having a peek inside your router’s configuration or routing table to see if it sees the Shake. If it doesn’t see it while it’s plugged into Ethernet, then I rather doubt that WiFi will work any better.
What is the status of the lights on the Shake? You should see the following:
However, if you are feeling adventurous, you may be able to follow a tutorial like this one to try and make WiFi work. Don’t say I didn’t warn you.
on another note: please drop the port 5000, this is no longer necessary.
making the URL http://rs.local
alternatively, navigate to URL http://rslookup.osop.com.pa/ in a browser on a computer running on the same LAN as the shake and see if it comes up there.
I’m at home. I’ll take a look on my WiFi. Thanks!
