Hello everyone! I was reading that the Boom is coming with Debian 8. The device is booting with the graphic environment or just text mode?
Thanks
Thanks
All of the Shakes and Booms have just a fairly minimalist text environment installed, since that both saves energy and frees up resources for other things. However, if you boot with an active HDMI connection (i.e. it’s connected to a monitor), you will be able to log in to the text environment locally via a USB keyboard. Most of the time, however, you will probably interact with it as a headless device via SSH.
Brilliant… I am actually using ssh. The manual says that is Debian 8, but could you bring me a link of the distro just to see more about it. I am trying to use a DDNS.
Thanks.
