The problem is here: In the past I use RS1d with vertical sensor All is going well with win SDR software . I am upgraded RS1D to RS3D and when I give the commandSeedlink IPport My IP: 18000 the system said there are connects too many monitoring channels and the graph works only curves on helicorder. There is also afect on Jamaseis software, because Jamasieis is also using seedlink IP port IP:18000… Grr
Any idea what could be wrong?
Thanks Marco
