Hello Rob,
thank you for the logs, they confirmed what I was suspecting. Your issue can be found in the postboot.log
file, where these lines explain that we are facing a DNS problem:
2021 009 19:18:56: Unable to resolve hostname 'raspberryshake.net', most likely no DNS server available
2021 009 19:18:56: No internet connection found
2021 009 19:19:06: Unable to resolve hostname 'raspberryshake.net', most likely no DNS server available
The first thing you can try, if you haven’t already, is simply to shut down your modem/router, wait a couple of minutes, and then turn it on again, to see if it was a simple issue with the modem/router itself.
If the connection still doesn’t work, then you can also try to change the DNS on the Shake, as explained in this page on our manual, Firewall issues? — Instructions on Setting Up Your Raspberry Shake, to see if this solves the issue. I’ll add some more info below.
There are two possible ways: setting a manual IP and DNS in the http://rs.local web config, or adding a line to /etc/dhcpcd.conf
in the Shake filesystem.
The first doesn’t require logging into the Shake. Navigate to rs.local
, make note of the Shake’s IP address, then click on the Settings
gear icon (high on the left) to access the configuration menu.
Fill out the DNS server field with a more reliable DNS service. OpenDNS
, which is 208.67.222.222
, is a good choice. You can also use Cloudflare
DNS service by entering 1.1.1.1
or Google
by entering 8.8.8.8
SSH into the Shake (guide here: How to access your Raspberry Shake’s computer via ssh — Instructions on Setting Up Your Raspberry Shake)
sudo service dhcpcd restart
nano /etc/resolv.conf
# Generated by resolvconf
nameserver 1.1.1.1
nameserver 1.0.0.1
