AM.R02EE station is not on the station Map
Dear All,
I am Cristian Neagoe from National Institute for Earth Physics, Romania. Recently we installed a raspberry shake AM.R02EE. The station is configured to forward data, the connection with the server is ok. The station also appears on https://shakenet.raspberryshake.org/ as the newest station, but unfortunately the station does not appear on the station view https://raspberryshake.net/stationview/
Can you help me?
Thank you in advance,
Best regards,
Cristian
hi,
it is there now. make certain to CTRL-F5 to refresh the local cache to force a clean fetch from the server.
Thank you very much,
Cristian
Hello sir Ivor, we are having the same problem as well. Recently we installed the geoberry “AM.R1E7D”. The station appears as the newest station in https://shakenet.raspberryshake.org/ , but unfotunately the station does not appear on the station view https://stationview.raspberryshake.org/
hello,
thanks for your report. after some investigations, there was an issue on the stationview server that has been resolved. your station is now visible there:
https://stationview.raspberryshake.org/#?net=AM&sta=R1E7D
cheers, enjoy,
Thank you for your quick response.
