Station Lat Long not matching Map Position
OK, I’ve come up with a solution, but if anyone knows a simpler or better way, I’d appreciate them sharing.
This is the code I’ve come up with to get the latest epoch data in the inventory:
inv = rs.get_stations(network='AM', station=slist[i], level='RESP')  # get the instrument response
        #print(inv[0])
        k=0
        while True:
            sta = inv[0][k]         #station metadata
            staOK = sta.is_active(time=eventTime)
            if staOK:
                break
            k += 1
        latS = sta.latitude     #station latitude
        lonS = sta.longitude     #station longitude
        #eleS = sta.elevation     #station elevation
        print(slist[i], latS, lonS)
        print(sta)
So I’ve set up a loop to test every epoch until it find the one that’s active at the eventTime. This should also handle retrospective events when an old epoch is relevant I think.
Al.
