Hello Wang,
Thank you for the new logs. It appears that the problem is still there, however, this time the Shake manages to find a time synchronization server (NTP), so that is a step forward.
Could you please reboot the Shake and then try the following procedure to see if it solves the connectivity issue?
Please access your
rs.local/page, go toSettings(the gear icon high on the left), and then theDatatab. Make sure that theForward Databox is checked, and then clickSave and Restart.The station should now be able to connect again.
If it does, then this error is caused by a known bug that we are examining and that will (hopefully) be solved in the next Shake OS v0.20 release.
