Raspberryshake get ip, connect to internet but can not be accessed through webinterface
Hi Stormchaser
I tried several times, and on several PCs and Macs with both rs.local and the actual IP address, all with the same result, “rs.local, or 192.168.50.100, refused to connect”.
The Nmap scan shows that ports 21, 80 and 5000 have been closed on the RaspberryShake, (only ports 111 and 22 are open), so it seems unlikely a connection can be made using the web interface.
Is there a way of downloading the logs via port 22 and SSH?
Thanks
CorofinShake
