Noise from PoE (power-over-ethernet) adapter
Hello timchurches,
Thank you for sharing your experience with that particular PoE unit. Definitely unfortunate.
If you want to try again (also minding Philip’s sound advice), you could check this post out: Power over Ethernet (PoE) - #10 by Hadders that describes a workingPoE unit that is not showing the noise you have highlighted.
