I just noticed my station is showing offline. I’ve rebooted it, but no change. Log files attached.RSH.R3B66.2021-11-29T22_55_23.logs.tar (3.1 MB)
- Jim
Hello WN1X,
Thank you for posting the logs from your Shake. It seems that there is no particular issue with the booting process, and the Shake can see our servers too.
Could you please try the following procedure to see if it solves the connectivity issue?
Please access your
rs.local/
page, go toSettings
(the gear icon high on the left), and then theData
tab. Try unchecking theForward Data
box and, after ~30 seconds, recheck it. Then,click save and restart.The station should now be able to connect again.
