I have a double question regarding transforming the data from stand-alone mode to sound files. I would like to sonify the data from the RBOOM recorded in a location with no internet.
The first question is if anybody can point me out to some guide on how to transform the data from the RBOOM to a sound file.
The second question is regarding the location of the mseed data in the SD card. I have the gps antenna and I was able to change the internal clock but I couldn’t locate the data in the sd-card. I used Filezilla to read the folder structure of the sd card.
After connecting, you may need to double click on the top folder of the structure (the one listed with ..) a couple of times before you can see the entire list of folders in the microSD card.
I trying to convert the miniseed data from the sensor to hertz in order to create a wav file. I am trying to do it offline transcoding the counts to ms and from ms to hertz.
Yes we are aware of the bug and we are working to correct it. Even if the filename appears as query it is in .mseed format. You will have, until the fix is in place, to manually rename it as, for example myfile.mseed, and it will be usable.
However, remember that this instrument measures a change in air pressure, so the relationship that can be found there is a count to pascal one. In both models, the sampling rate is the same 100 samples per second.
I have an additional question if the sensitivity of the sensor is the following one: 56,000 counts/ Pascal +/- 10% precision
Could you point me in the direction to find a formula to convert that into meters per second?
Thank you very much!
Miguel
