I show my station is up and running and has been.
There seems to be a bigger problem because on the map of globe you should notice that the USA has no stations indicating as being on-line.
I went back to look at map and it looks like the bulk of the shake network is down.
My shake is running, my network is up and connected so the problem appears global and downstream from me.
hi there,
that’s strange, a screenshot below, just now, is what i see on stationview at the moment. what client are you using? your observation remains the same?
