Server not connecting RS1D
Hi, I have a new shake set up RS1D, but it doesn’t connect to the server
“Server Connection : Not Connected”.
I tried to check other topics without solving the problem.
Offline mode is off
RSH.RA0D7.2022-01-15T15_54_03.logs.tar (1.0 MB)
Hello qWide, welcome to our community!
Thank you for the logs that you have provided. Nothing wrong appears to be present in them, and the Shake boots up as it should without issues.
Could you please reboot the Shake again and then try (even if you have already) the following procedure to see if it solves the connectivity issue?
