Dear Raspberry Shake Support Team,
I am contacting you regarding an issue with our Raspberry Shake station.
Station information
Model: Raspberry Shake 4D (RS4D)
Station ID: R9AF3
The station had been operating normally and transmitting data to the Raspberry Shake platform. The data were publicly available through the Raspberry Shake network.
However, several months ago, we noticed that:
- Waveforms were no longer visible on the Raspberry Shake web platform.
- The station disappeared from Station View.
- No new data appears to be reaching the Raspberry Shake servers.
To investigate the problem, I accessed the instrument via SSH and checked its status.
Current Status
The device is still accessible through rs.local , and the status page reports:
- Internet: Online
- Services: Down
- Server Connection: Inactive
In addition, when attempting to change settings or reboot the device from the rs.local interface, a password is requested. However, after entering the password, the requested action does not proceed.
Diagnostic Results
Network Connectivity
The instrument appears to have internet access and can successfully reach Raspberry Shake infrastructure:
PING hzcaps1.raspberryshake.org (188.40.209.188)
Reply received successfully.
Raspberry Shake Service
The Raspberry Shake service is failing during startup:
â—Ź raspberryshake.service - Raspberry Shake Boot Script
Loaded: loaded (/lib/systemd/system/raspberryshake.service; enabled)
Active: failed (Result: exit-code)
ExecStart=/usr/local/bin/postboot.rshake
(code=exited, status=1/FAILURE)
The service log shows that the boot script begins execution and proceeds through several initialization steps before terminating with exit status 1:
Jun 18 05:22:53 Starting Raspberry Shake Boot Script...
Jun 18 05:24:19 raspberryshake.service: Main process exited, code=exited, status=1/FAILURE
Jun 18 05:24:19 Failed to start Raspberry Shake Boot Script.
Storage Status
The root filesystem is completely full:
Filesystem Size Used Avail Use% Mounted on
/dev/root 7.4G 7.3G 0 100% /
Inode usage is normal:
IUse% = 39%
Most of the used storage appears to be archived waveform data:
4.2G /opt/data/archive
1.9G /opt/data/archive/2025/AM/R9AF3
2.4G /opt/data/archive/2026/AM/R9AF3
Questions
Based on these observations, we suspect that storage exhaustion may be related to the service failure, but we would appreciate your advice.
Could you please advise:
- Whether the full root filesystem is likely to be causing the Raspberry Shake service failure.
- Which files or directories can be safely removed or archived to recover disk space.
- Whether there is a recommended recovery procedure for this situation.
- How we can restore communication with the Raspberry Shake servers and make the station visible again in Station View.
I will be happy to provide any additional logs, screenshots, or diagnostic information if needed.
Thank you very much for your assistance.
Best regards,
