Remote Reboot
Is there a way to reboot your RS&BOOM remotely, when you are not on the device’s local Wifi network?
Hello Tomfinley,
Yes, you can install (it is quite straightforward even if there are many steps) ZeroTier and then you will be able to control your RaspberryShake via command line through it.
We have a guide here on our manual: How to connect to Raspberry Shake remotely — Instructions on Setting Up Your Raspberry Shake
I suggest to follow the adviced tutorial, it makes everything easier.
Once everything is configured, you can then reboot the Shake with the command sudo reboot, after you have logged in.
Thank you very much for the information!
No problem at all Tomfinley, you’re very welcome!
