Hi, why my Raspberry Pi 4 8 GB showing as Unknown Model ?
hi charles,
can you provide some more information please? is this causing you a problem? where do you see this, exactly? is this a different Pi than you were using before? do you have another one that you can swap out and test with? are you able to log in to the Pi itself and interact with the command-line and execute linux commands?
please provide as much information as possible so that we can look into this issue further.
thanks in advance,
