Question about what is included
Hello!
I want to know what the product description of the self kits mean when it says „Cables not included“. What cables specifically?
Kind regards,
Christian
There are two connections to the RaspberryShake: The power cable, which (usually) is attached to the power supply that you have to buy to power the device - basically the same one that you would buy anyway with your R-Pi that you also have to provide. The other connection is the ethernet (cat 6e) cable that connects the R-Pi to your router/switch.
Nothing expensive/difficult there. The hardest part to obtain right now is the R-Pi. They are in short supply.
Thank you for the information!
