Hello Luffe, thank you for the new logs.
The ntpq
outputs show that the Shake manages to find primary and secondary NTP servers, but always connects to different ones. However, in this case, the Shake is not booting because the Pi board doesn’t see the blue Shake board above it:
2025 154 08:48:13: Unable to read Firmware version number off of Serial Port /dev/serial0 after trying for 15 seconds, cannot continue!
2025 154 08:48:13: Is the Pi computer connected to the Raspberry Shake Board? Please confirm and try again.
This, together with buffer overflow/gibberish errors seen also in previous logs:
2025 154 09:52:41>> No Data has been received from the MCU in 12 read attempts.It appears the MCU is not transmitting data. This is a fatal condition and should be investigated if this condition persists!
2025 154 09:52:41>> Data has been successfully received, fatal condition resolved.
2025 154 09:52:41>> internal error: buffer overflow! cannot process read data...
2025 154 09:52:41>> buf: Ok¨M¸²„Q'TI I]ª'”E'AA
2025 154 09:52:41>> X „EœJ]ŠäL]ª
2025 154 09:52:41>> AAºEBaƒaÀ…[ AUTEáE‹UñDIÀÕEáÈ‹U]FIÀħÔEÁE
Indicate that something may not be quite right on the hardware side. Let’s do this, following a slightly altered version of our standard troubleshooting path:
Please turn off the Shake and then check if all the connections between the sensor, the blue Shake board, and the Pi board are still solid and free from dirt or any other element that could compromise transmission. As you have already disassembled and reassembled the Shake, this should be a quick operation. However, if you require them, you can find recommended ESD (ElectroStatic Discharge) guidelines and assembly/disassembly video guides here.
Once done, and if this check confirmed that all connections are good, then I would check if the current power supply is continuing to deliver a stable voltage between 5.0 and 5.2V and a current of at least 2.5A at all times (3.0A if the Raspberry Pi board that is being used is a RPi4), as a decrease in power could lead to data services interruption. And, if you have another Pi power supply that you know is in working condition, please try exchanging the current one (even if you already exchanged it once) with that and see if the Shake now works correctly for extended periods.
Lastly, I would recommend re-burning the microSD card again (or using a different microSD) after formatting and erasing all its data/partitions first (you can use DISKPART for this as it is very efficient), and see how the Shake behaves with the newly installed system, removing potential issues derived from corrupted files. I will leave the burning instructions link here for your convenience: microSD card topics
And, when you start the Shake again after all the above, please check if the LED lights on it are behaving as expected.
