Hi, my internet connection was down for couple of hours. After that I see data producer was OFF. Now internet connection working again, but shake could not establish server connection. I am restart RS but no luck.
Here my logs:
RSH.RCF63.2021-11-08T14 26 10.logs.tar (3.5 MB)
Hello Marco,
Thank you for posting the logs from your Shake. It seems, from them, that the booting process goes smoothly so the issue should not be there.
Could you please try the following procedure to see if it solves the connectivity issue?
Please access your
rs.local/
page, go toSettings
(the gear icon high on the left), and then theData
tab. Try unchecking theForward Data
box and, after ~30 seconds, recheck it. Then,click save and restart.The station should now be able to connect again.
Stormchaser good work. Now everything working just fine, thank you.
Marco
No problem at all, you’re welcome.
