New Shake not connecting to server
New install can be pinged on LAN and web config works, but Server Connection show 'Not Connected.RSH.R6087.2021-01-18T22_36_36.logs.tar (728.5 KB)
Hello markmaj, welcome to the community!
Thank you for the logs. From them, it appears that the DNS address ‘10.58.85.1’ is not getting a connection to our servers. These lines make the issue clear:
2021 018 18:23:58: Network detection failed, unable to curl or ping common sites
2021 018 18:23:58: No internet connection found
The first thing you can try, if you haven’t already, is simply to shut down your modem/router, wait a couple of minutes, and then turn it on again, to see if it was a simple issue with the modem/router itself.
If this has not solved the issue, then please shut down your Shake again first, then your modem/router. Wait for a couple of minutes, then restart your modem/router, and when it’s back online, please check from your pc/laptop if the following ports are open (do not start the Shake now):
port 55555 [TCP]
port 55556 [TCP]
If the connection still doesn’t work, then you can also try to change the DNS on the Shake, as explained in this page on our manual, Firewall issues? — Instructions on Setting Up Your Raspberry Shake, to see if this solves the issue. I’ll add some more info below.
  1. The first doesn’t require logging into the Shake. Navigate to rs.local, make note of the Shake’s IP address, then click on the Settings gear icon (high on the left) to access the configuration menu.
    Fill out the DNS server field with a more reliable DNS service. OpenDNS, which is 208.67.222.222, is a good choice. You can also use Cloudflare DNS service by entering 1.1.1.1 or Google by entering 8.8.8.8.
  1. SSH into the Shake (guide here: How to access your Raspberry Shake’s computer via ssh — Instructions on Setting Up Your Raspberry Shake)
    sudo service dhcpcd restart
    nano /etc/resolv.conf
    # Generated by resolvconf
    nameserver 1.1.1.1
    nameserver 1.0.0.1
Changing the DNS server to OpenDNS worked. Thanks Stormchaser!
That’s perfect, great to hear it!
Enjoy shaking!
