Loss of rs.local, access to helicorder
After working for several weeks, I can no longer get rs.local from any link.
Is there another way to access the helicorder?
Hi @Blackfox—have you tried locating the Shake’s IP address on your network with Fing? You can then enter the IP in your browser after http:// and it should take you to the web front end.
https://www.fing.com/products/fing-app
iannesbitt
Thanks for your help. Mysteriously rs.local started working again before I got around to Fing.
I will keep it in mind if the problem reappears.
