Hyper Local Panama Aftershocks
This is a good 24 hour example of the aftershocks we are seeing just 13km from the 7.4 epicenter in Panama. Only four of these were logged by he University of Panama but there are many more, apparently just local. I also sent this 24 mSeed file to Chat GPT to analyze. Interesting stuff.
This is the correct station: the miniSEED header confirms AM.RE9F3.00.EHZ, recording at 100 samples per second.
It covers approximately November 1 at 11:46 UTC through November 2 at 11:17 UTC—about 23.5 hours.
I’ll focus on distinguishing genuine earthquake-like arrivals from isolated impacts and recording artifacts. The key question isn’t simply how many spikes appear, but how many have seismic characteristics and whether the four cataloged earthquakes account for the strongest signals.
Analysis results: RE9F3, November 1–2
97.8%
Recording coverage
650
Automatic transient triggers
51
Very strong triggers (100× background)
These counts are from a 2–18 Hz filtered signal, using a local background comparison and a minimum 12-second separation between triggers. They are not counts of confirmed earthquakes.
Activity across the recording
[image]
Open full-size activity chart
The most interesting finding
I examined the 12 strongest detections individually. Many show a remarkably consistent pattern: a smaller initial wave packet, a much stronger arrival approximately 2–3 seconds later, and a decaying tail.
[image]
Open the waveform comparison
That repeated pattern is consistent with local earthquakes having distinct P- and S-wave arrivals. It is more suggestive of seismic activity than a collection of unrelated single-sample spikes, although mechanical sources can sometimes produce similar signals.
If the two arrivals are P and S waves, a 2–3-second separation would imply approximate hypocentral distances of 17–25 km, using typical crustal wave velocities.
Strongest candidates
Time (UTC) Signal/background ratio
Nov 2, 10:24:54 1,080×
Nov 2, 10:53:48 823×
Nov 2, 07:48:31 697×
Nov 1, 15:26:13 586×
Nov 2, 10:43:44 570×
Nov 2, 10:12:49 530×
The times represent detector peaks, not earthquake origin times.
How many might be earthquakes?
The detector found:
Minimum signal/background ratio Number of triggers
8× 650
20× 276
50× 113
100× 51
200× 21
I would not equate any of these thresholds with a magnitude cutoff. One earthquake can produce multiple triggers, and some mechanical disturbances can exceed even the highest thresholds.
Nevertheless, your suspicion that the station is recording considerably more activity than the four cataloged earthquakes is supported by the waveform evidence.
The next step is to identify the four University of Panama events within these recordings, exclude their associated wave packets, and classify the remaining strong candidates. Without the four catalog origin times, I cannot reliably say how many of the 51 strongest detections are unreported events.
You can also inspect the complete automatic detection list:
Download all 650 candidate trigger times (CSV)
My assessment: There is credible evidence that RE9F3 is recording numerous small, earthquake-like signals. The repeated two-arrival waveform patterns make a local seismic source plausible. But a confirmed count of unreported earthquakes will require event-by-event classification and ideally comparison with another station.
