Rather than loading the web interface, how do I do this from the command line in unix. IE I know how to set to a static IP, but how to set my email, or tell the shake to upload data, floors, location all that good stuff.
Hi @KF7MAX—are you having an issue with configuring one of these settings via the web interface? If so please let us know.
We do have other ways of doing this, however the web interface has failsafes built in that are designed to prevent impossible values from being set. A streamlined command line configuration may be possible in the future, but right now unless you are having an unrecoverable issue with the front end we recommend using that.
