Historical miniSEED downloads returning HTTP 204 — previously available data (June 2019)
Subject: Historical miniSEED downloads returning HTTP 204 — previously available data (June 2019)
I’m preparing a comparison of seismic recordings from three monitoring stations and have encountered a problem retrieving historical miniSEED data through Raspberry Shake’s FDSN dataselect service.
On October 12, 2026, I attempted to retrieve data from station AM.RB53D.00.SHZ covering June 19, 2019, 01:58–02:12 UTC:
--2026-10-12 10:11:59--  https://data.raspberryshake.org/fdsnws/dataselect/1/query?net=AM&sta=RB53D&loc=00&cha=SHZ&start=2019-06-19T01:58:00&end=2019-06-19T02:12:00
Resolving data.raspberryshake.org... 188.40.209.188
Connecting to data.raspberryshake.org|188.40.209.188|:443... connected.
HTTP request sent, awaiting response... 204 No Content
2026-10-12 10:12:00 (0.00 B/s) - ‘RB53D_20190619_0158_0212.mseed’ saved [0]
To determine whether this was specific to RB53D, I repeated a request for nearby station AM.RCB43.00.SHZ, using a command that had successfully retrieved data on October 2:
wget \
'https://data.raspberryshake.org/fdsnws/dataselect/1/query?net=AM&sta=RCB43&loc=00&cha=SHZ&start=2019-06-19T01:58:00&end=2019-06-19T02:12:00' \
-O RCB43_20190619_0158_0212.mseed
October 2, 2026 — successful response:
--2026-10-02 16:46:28--
HTTP request sent, awaiting response... 200 OK
Length: unspecified [application/vnd.fdsn.mseed]
2026-10-02 16:46:29 (311 KB/s) - ‘RCB43_20190619_0158_0212.mseed’ saved [51712]
October 12, 2026 — same request now fails:
--2026-10-12 10:16:01--
2026-10-12 10:16:02 (0.00 B/s) - ‘RCB43_20190619_0158_0212.mseed’ saved [0]
Both requests reached the same IP address, and the station, channel, location code, and time interval were unchanged.
I retained the successfully downloaded 51,712-byte miniSEED file from October 2, so I can confirm that this data was previously available.
Could you please clarify:
  1. Is there currently a technical problem retrieving historical waveform data through the FDSN dataselect service?
  2. Has there been any change in the retention or availability policy for historical data, particularly recordings from 2019?
  3. Is the requested AM.RB53D.00.SHZ recording available elsewhere, or could you provide the miniSEED file for June 19, 2019, 01:58–02:12 UTC?
If this is a temporary technical issue, an indication of when historical downloads might be restored would be appreciated.
Thank you for maintaining this valuable seismic data archive.
Hello JohnPoole, and welcome to the community!
Thank you for notifying us about this issue. I forwarded it to our server team so they can check what might be causing it.
I will update you as soon as I have news from them.
Hello again JohnPoole,
Everything should be back up and working as usual now. There has been no data loss, and your query downloads the intended miniSEED file.
Could you try again when you have the chance?
As a note, AM.RB53D.00 doesn’t seem to have a SHZ channel as far as I can see.
Thank you again for your notification.
Greetings and thank you!
I now tried with success both downloads. Note: RCB43 has channel SHZ, whereas RB53D has channel EHZ (suggested by Ian).
–2026-10-15 10:20:02-- https://data.raspberryshake.org/fdsnws/dataselect/1/query?net=AM&sta=RCB43&loc=00&cha=SHZ&start=2019-06-19T01:58:00&end=2019-06-19T02:12:00
Resolving data.raspberryshake.org… 188.40.209.188
Connecting to data.raspberryshake.org|188.40.209.188|:443… connected.
HTTP request sent, awaiting response… 200 OK
Saving to: ‘RCB43_20190619_0158_0212.mseed’
RCB43_20190619_0158_0212.mseed [ <=> ] 50.50K 309KB/s in 0.2s
2026-10-15 10:20:03 (309 KB/s) - ‘RCB43_20190619_0158_0212.mseed’ saved [51712]
and
–2026-10-15 10:20:48-- https://data.raspberryshake.org/fdsnws/dataselect/1/query?net=AM&sta=RB53D&loc=00&cha=EHZ&start=2019-06-19T01:58:00&end=2019-06-19T02:12:00
Saving to: ‘RB53D_20190619_0158_0212.mseed’
RB53D_20190619_0158_0212.mseed [ <=> ] 96.50K 578KB/s in 0.2s
2026-10-15 10:20:49 (578 KB/s) - ‘RB53D_20190619_0158_0212.mseed’ saved [98816]
Perfect! Glad everything is working as it should!
