Green light stays on
I have a shake which was working absolutely fine for years. It dropped off three weeks ago and usually this means we have had a power cut, the SD card is corrupted and I could fix it with new burn of the disc. I tried this twice and now it starts, the blue board light is on, the red light is on then the green light is on but stays on permanently. I cannot access the pi via rs.local.
I have a designated power supply.
Please help me work it out
Graham in tasmania
Hello Graham, and welcome back to the community!
Since you have already tried a re-burn twice, and this happened after a possible power cut, you may need to swap the current microSD card for a new one.
The power cut may have corrupted it in a way that even a clean re-burn can’t fix, as the Pi’s constant green LED shows.
If even a new card doesn’t work and the green LED stays on, we’ll need to investigate the Pi board further. Let me know how the test with a new microSD goes!
Hi -thanks for the reply. I have tried it on two new separate micro SD cards -with same result.
can I send it back for repair? I also have an older model shake that hasn’t worked for years that I wouldn’t mind sending in for a look as well. I can send both if you agree.
Graham
Hello Graham,
Yes, we can do that too if you prefer, and for both Shakes.
If you send an email to sales [at] raspberryshake [dot] org, referencing this conversation, we can take it from there.
I bought two new cards from RS to try and the same problem happened- green light stays on. Does this mean the USB reader is faulty? can I change it for a basic RPI model and try that easily?
Hello grazhobart,
Can you tell me how long the green light stayed on this time? If you haven’t timed it, no issue; you can just try to restart it and tell me if the green light remains on for 30+ minutes without blinking. If so, the reader on the Pi may have developed a fault.
Thus, regarding swapping the Pi, yes, you can certainly do it. Just make sure that the new Pi board is compatible with the Shake (you can find a list here).
And, if you require assembly instructions, we have detailed videos here.
Let me know what you find out.
Yes- it stayed on for hours. I will swap out the Pi next as I have ordered a couple of fresh new ones. Thanks for the help.
