Can you share the proper format or burn instructions for the OS files to a new Micro SD card for RS4D?
I’m having a hard time using a new 32 GB Micro SD in my new shake that comes with a Type-C connector. But it doesn’t have an HDMI port, so I can’t figure out the problem. What I always do is simply copy the OS files, paste in into a Micro SD card, then plug it into my shake. However, it doesn’t work the same way with the new shake that has a Type-C connector.
Hello waw0102,
No trouble at all. You can find the format/burning instructions here.
The document is divided into three sections:
- The first shows the standard installation procedure
- The second illustrated an alternative one (using a third-party software)
- The third details a step-by-step process to low-level format the microSD so it’s ready for the OS
If you still have issues, please provide as many details as possible about the errors you are seeing so that we can see what can be done.
