This is a minor thing, but could have implications for those trying to safely shutdown their Rshake unit.
I have noticed that when I choose the ‘shutdown’ option on the ‘actions’ page of rs.local, there is often (but not always) a long delay between when the rs.local page has said the unit has shutdown and when the sensor does actually safely shutdown. What I mean by a safe shutdown is that the green led light on the Pi computer flashes 10 times and then turns off, leaving only the red led light on. The delay I mention has often been anywhere between 30 s to 5 mins.
Doesn’t this risk damaging the sd card if people are hasty to remove the power after the rs.local page says the unit is shutdown safely but in actual fact it isn’t?
I hope this makes sense. I understand if there isn’t an easy software or hardware solution to this, but I would recommend at least adding a warning message to the rs.local popup message to say that the power needs to be kept in for at least 5 mins to make sure the sd card is not damaged.
