Just an observation from R5A78 SHZ. When I looked at DataView 24 hour plot for 10/10 UTC I see quite a few periods of missing data. When I look at data from a nearby site (R6559D EHZ) I see significantly fewer instances of missing data.
I mention this only because I also collect my data in real time with direct UDP data and I see no similarly missing data (the station is in Kapa’au, HI and my data collection system receiving the UDP data is in San Jose, CA). I’d expect my connection to be at least as lossy as yours, but that seems not to be the case and I thought you might consider it an issue worth examination. I can send you my raw data and /or the plots I generate with the data.
Terry (Backer #5)
