Could you please let me why my sensor is not getting connected to the server? I have tried the reboot and forward on and off. Still,RSH.R859A.2022-02-22T22_07_34.logs.tar (3.4 MB) the server connection is unticked. Please help.
Station Info
Data-Sharing Mode : ON
Data Server Conn : OFF
Save Data Days : 7
Heli Scale : 0.5
Station Name : AM.R859A.00.E[HZ,NZ,NN,NE]
Geophone : OSOP
You have data connection turned off.
This is what you need to change:
Click the Forward Data button to turn it off, then again to turn it on, then the “Save and Restart” button.
It should connect after 30 seconds or so – at least, that is how it works for me.
Hello chanthuj,
Thank you for the logs that you have posted. It seems that the stand-alone mode
has been activated for this unit, and that is why the Shake cannot connect to our network.
2022 053 22:05:09: STAND-ALONE Mode ON, not checking for an internet connection
2022 053 22:05:09: STAND-ALONE Mode ON, not checking for a valid IP address
Please navigate to rs.local/
, then Actions
icon high on the left, then ACTION
tab, and click the TURN STAND-ALONE OFF
button. After the process has ended your Shake should be able to connect.
If not, please follow the instructions in the message by Philip above me.
